Using with a Kindle Fire
I have a Kindle Fire and found an Arlo app in the app store. However, none of the information about the cameta indicates that it can be used with a Kindle Fire.
Can the Arlo Pro be used with a Kindle Fire?
Message 1 of 3
1,532
I have a Kindle Fire AND the regular Arlo was supported up to about early 2016 if I remember right... then the sw was updated and support stopped.
So, the answer at this time is No...
Message 2 of 3
1,526
Zachariah0911,
Are you able to download the app? As long as your device meets spec you should be able to use it.
Please let me know your device model/OS version if you have trouble.
Message 3 of 3
1,483
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
