Time Zone Incorrect -- Will not reset
  • 1 Reply
  • 1341 Views
write2caro
My system is set to Pacific instead of Eastern.  I go to the appropriate settings online, change to Eastern, and reboot.  It looks as though the correct time zone is then set.  After a short time, it reverts back to Pacific.  Any fix for this?
write2caro,
After changing your time zone to eastern are you making sure to click the Save button to commit the change? If using the web client, the save button is in the top right hand corner of the screen and must be clicked in order to commit changes made.
