  • 1 Reply
  • 1604 Views
Stiania79
Hi,
I have set my motion dedection from 10 pm to 7 am all days, but would also like to have the possibility to set from 9 am to 15 pm (when at work) and just all day, as it will go off when we all leave for work/kids to school... is that possible? Seems it will not allow this?
That apart - works great 🙂
Thanks. Best regards Stian (Oslo, Norway)
Yes it is possible...
set the first block ON from 10PM to 12 Mid
add ON 1201am to 7am on next day
then add 9am to 3 pm on
 In this case as you drop the 'second' ON time , the bottom drag line may NOT be movable , so add an OFF.
** the real trick is IF you can't drag one of the ON time ends, drop an OFF into the bottom ( or top ) of the ON time to allow movement**
looks like this ;
 PS... DON"T forget to SAVE schedule before exit
looks like this ;
