Smart d link plug
  • 1 Reply
  • 2223 Views
crw
Hi. Has anyone tried to use the Arlo PRO with these smart plugs that will turn on a lamp when there is motion ? If so, can you please tell me your experince and which smart plug you recommend ? Is it a D-Link smart plug ? Thanks very much
Paul_FCCL
Prodigy
Prodigy
I tried with IFTTT, using D-Link smart plugs and Arlo.Couldn't get it to work, gave up after a while. I read it may be working ok for others. They're supposed to integrate well.
Paul
