Setting different modes for different cameras--how???
Can someone please help me understand how to set one camera to motion detection and the other to "motion off?" I would like that to be its own mode that I can select at any time. I have now spent hours trying to figure it out and I would love some help. Thank you.
Message 1 of 2
1,705
Set up a rule for each camera in Settings if you haven't already done so. Then go to Modes and set up as many as needed to serve your purposes. In each mode you can enable or disable cameras as desired. Be sure save at each step. You can then go to the Mode tab and set a schedule or simply select the Mode you want active.
Message 2 of 2
1,696
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
