Saving Camera Settings
  • 1 Reply
  • 2714 Views
MotoJimmr
After changing the motion sensitivity I can't save it as there is no longer a "back button" where there use to be?!?
When it was there, I always had to scroll down to the very bottom of the page, but at least it was there...
From Arlo instructions:
If you are using a computer, click Back > Save.
Your motion sensitivity settings are saved.
The SAVE button is on the bottom of previous page.... back is is the upper left .
But  as you say , now it appears gone... but no real issue ... JUST Click on EDIT RULE and that will take you to the previous page, go to bottom and SAVE
