Rotate image 90 degrees?
  • 2 Replies
  • 22566 Views
  • 10 Likes
pcom
I've got my Arlo focused on the walkway leading up to my house which is longer than it is wide. Are there plabns to provide for 90 degree image rotation in the app? That would let me turn the camera on its side and have more vertical resolution where I need it.
Don't know if there are plans to do so as requested.. Arlo team can answer that.
But, in the past what i have done is use the camera in the sideways rotation and then downloaded any pics/video I've needed.  Most simple pic software will be able to rotate the jpg and/or there is Microsofts movie maker which should do the video too ( tho i use an aftermarket product )
JamesA
Arlo Employee
Arlo Employee
There are no immediate plans for this functionality, but I recommend that you place this into the ideas board. The product and development teams will be reviewing the ideas with the most kudos for consideration in future functionality.
