Reset to factory setting
  • 23168 Views
  • 4 Likes
jcmesina
I deleted the factory all motion on rule by mistake. How do I reset my base station and camera to the original factory settings so I can start over?
  • Perform a factory reset on your base station.
    Push the Reset button (on the back of the base station) and the Sync button (on the side of the base station) for about 10 seconds or until all the LED lights on the base station blink amber. This procedure returns the base station to its factory settings. If your cameras were synced to the base station, you might need to sync the cameras again after the base station comes back online. For more information, see How Do I Set Up And Sync My Arlo Cameras?.
R_Lowe
Luminary
Luminary
You could maybe instead but certainly supplementally go to Settings/Base Station Settings, then click on the "RESTART" button at the very bottom of the right panel.
I don't believe that will bring back the 'default modes' that were deleted
