Notification cooldown?
  • 2 Replies
  • 4712 Views
whitenack
Is there a way to set a notification cooldown?  Right now I am getting several notifications for each event, because the Arlo is breaking the event up into multiple recordings.  It would be great if I could limit the number of notifications I get in a single event or in a certain amount of time.
brh
That is the way the system was designed, I'm afraid. Have you set the cameras to record up to two minutes before ending recording?
I believe that there have been suggestions posted to allow the recording to extend until the motion stopped, but I don't know the status of that.
Brian
whitenack
Thanks for the reply.  I was hoping to not have to set a recording length, as that creates other aggrivations.  Thanks all the same.
