Night Vision Configuration
  • 3814 Views
  • 2 Likes
user2
Provide the ability to enable night vision without the LEDs.  I have an Arlo-Q pointing out a window in my shed, which works great during the day, but at night, the LEDs create a blinding glare on the glass.  There is plenty of light in my backyard, so I'm still able to see a decent image with night vision turned-off; however, if I were able to turn-on night vision without the LEDs, then the image would be crystal clear.  Thanks for your consideration.
You can already turn off the IR illuminators in settings.
The camera will auto shift to B/W when light level are low reguardless of the IR on or off
Arlo1234
Is this also true for the Arlo system and not just Arlo -Q.  I cannot seem to locate in settings
Yes, all Arlos have the same thing.  Settings, My Devices, your camera, Video Settings, Night Vision.
