New Camera Not Detecting Motion
  • 5 Replies
  • 2637 Views
2112
Hi
I had to replace a camera in my Arlo network.  The new camera does not detection motion, yet the rest of the cameras do.
The new camera is mounted in the same position as the prior camera, which had no issues in detecting motion on schedule.
I'm not sure what else to provide for information.
5 REPLIES 5
First thing is to make sure the New cam is in your current mode....
any cam not in the running mode will be off.
When all Armed,check the "running man"on the new cam, he should be black...means active...if gray the cam is off and won't record
Thanks.
Do you mean this running man?
2112 wrote:
Thanks.
No... that is in test mode and no record will occur ( just to show sense level response )
Running man is viewed from the CAMERA view screen.
This is the running man I mean. ( below camera name, left of wifi signal )
Gray is Motion record is OFF, Black is ARMED for motion record.
Thanks.  This running man is grey.  I don't know how to activate him, since they are on a schedule.
The running man does turn black if I switch to all armed.  But when I switch back to schedule, he is grey again.
This was a replacement camera I added to an existing schedule and network.
What can I do next?
That simply means that the camera hasn't been added to your modes and rules.  Edit them and add the camera.
