Motion Timer
  • 9 Replies
  • 4799 Views
  • 2 Likes
caser41
Hello. I received 2 Arlo camera system for Christmas. So far I am satisfied with the system with one exception: It doesn't make any difference were I set the timer, it will still only record 9-10 secs of motion. I have searched the 'community' and can not seem to find the answer to this perplexing problem. Please advise" G.L. Smith Model: Arlo wireless 2 camera system Firmware: 2.0.1 730_1137 OS: OSX 10 El Capitan 10.11.2 Both Camera's are outside. Thank You
Try this;
Go to MODE, click on current mode so list shows up
( we'll use ARMED as example )
Go to ARMED, click edit pencil
Pick camera and click on EDIT
go to second section "then do the following " click on the edit pencil in record
set the lenght of time, click BACK button at top
Once you go back one level at bottom of page is CANCEL or SAVE ( click save )
Now you can exit out and new setting saved.  ( must be done for each camera )
9 REPLIES 9
You are saying you reset the lenght of record time in the settings AND saved?? This must be done for each camera .
If you did and when you go back , do the settings still retain the longer time set?
Try a power button reset of the base and see if that helps
caser41
Hi ..  I should reply here I guess.
I go in and set the length of the record time from 10 secs to 30 secs or any other time.  I do not see where to save it or a button to do so, but if I go out and come back in, it is still set at the new settings.  Perhaps I am missing something?
And yes, Morse Code is faster than typing!
Thanks for your help.
Try this;
caser41
TomMac.  I believe the 'save' step is what I missed.  It should work now.  Thank you for your expertise..
caser41
Hi TomMac.  Coming back to you again for more advice.  Here is the story.  If I turn on 'armed', the camera's record to my new setting times.  However if I have it 'scheduled' (in my case midnight to 6a.m) it will only record for the 10 secs or so.  For example: the paperboy comes around 4a.m.  the motion detector picks him up coming up the drive way, and records for 10 secs. He disappears out of site for about 4 secs or so, the motion stops at 10secs.  When he leaves the mail box, no motion is picked up even though he goes back the same way.  Hope you can understand & this makes sense to you.
Problem #2:  A vehicle will drive by, and all I get is the rear of the vehicle disappearing out of the frame. ??  I guess I could get around this by getting another camera & having it start up a second one.
I would like to think it is me a the root cause of these problems, and not the camera, I would hate to have to get other camera's.
Thanks for the help...
Joe
If your saying you have the record time set for 30 sec but if that MODE isused in the  schedule it only records for 10... I don't have a clue !
Tho i can say that defualt time to record is 10 seconds... so I would start by confirming the times are set properly .
The most common problem I see with outside cams is the user trying to cover to much area... add to that a start up delay of anywhere from 1-5 secs for people, you only get the tail end of action ( start up time is a big variable ... I get 1-2 sec max , others say they get 3-5 ...amybe a lot to do with range, interference, etc )
I've found the detect distance is best is about 20ft max... and the PIR is more sensitive on the outer edges ( ie cross motion ) so maybe re think what you trying to do... Yes you can use one camera to detect and record on a second cam and in some cases it works really well ... YMMV .
caser41
Hi TomMac.  Here is where I am at now.  When I first set up the cameras, the timers were at 10 sec.  My next step was to set a schedule which happened to be midnight to 0600hrs.  Ok later I changed the timer to 20 or 30 secs.  It made no difference to the time when recording on the times I set.  So today (Sunday) I made sure the timers were set at 30 secs.  And set another schedule, lo and behold it worked.  So I have deleted my 2400 - to 0600 time and reset them.  I am thinking that may solve my problem.  Here's hoping.
Thanks for letting me use you as a sounding board.
Joe
A possibility is that your old modes and schedule was transferred via the recent update.  There have been various problems with the old modes that have been fixed by creting new ones.  Don't know why, just is.
Yes, I deleted all my old modes and created new ones that were the same BUT it made a diff in how reactive the cams were ...esp in nested modes
