Motion Detectors
  • 1 Reply
  • 7651 Views
mgoodman
I am still having problems getting my cameras to activate fast enough to capture when someone enters the area I want to record. more videos already at 90%, any higher wind triggers false flags.   I have added an additional camera in the opposite direcection and set it's motion detector to record on the camera I want but this has only improved the timing slightly.  I know it's suggested to move the camera to the side so motion comes across it, but then it will not be viewing the area I want (and isnt that the whole point?)  Instead of having to move cameras out of optimal recording position so that they trigger the motion detector (actually working the way they should) wouldn't another solution be if we could add separate motion detectors (not cameras @$159.99 each)  to the system that  we could put around the perimeter.
Toggi
I agree, Netgear need to do something about this pretty soon. If I knew the motion sensor is this slow, I would not but so many of them.
