Motion Detection Test Level Saves on App but not Via PC
  • 2 Replies
  • 1672 Views
Fezick
Just a recommendation here. When in Motion Detection Test mode, you can actually save the last motion level percentage via the apple app but you can't save it via your PC/desktop. It would be nice to be able to save it from both places since it is available in one place. That way I don't have to remember exactly at what setting I have tested motion for each camera.
I suspect you're not saving the rul when you set it in the browser. I just tested and changed my sensitivity. There's no save button there but going back to the rule screen (one step back) had the save button at the bottom. Perhaps you're not noticing that because you need to scroll down to the bottom to see it?
Fezick
Nope, I am not talking about the setting in the rule.  Subject line specifies the Motion Detection Test Level and this is on each individual camera under settings.  If you go there on an ipad via the app, you can save the test setting.  You cannot save the test setting level via the browser/pc.  It should be available in both places.
