Modes
  • 1 Reply
  • 2247 Views
md75
I would like to create a mode that configures all cameras such that they will record, but not send a notification.  When I attempt to do this, by creating rules for each camera, then creating a mode that includes all said rules, the mode creator will not allow me to select more than one of those rules-- it just switches the green checkmark in between them.
Maybe I don't understand your statement....
The email notification are set in the RULES for each camera. If you want to turn them off, do it in the rule. Make sure you save when changing the email and then when you exit.
The MODES control what cameras are active... all the MODEs are the same and will contain every camera you have, the only diff is if the camera/cameras is/are active or not.
Remember only one MODE can be active at a time.
BTW, one of the default Modes is ALL cameras ON already.
EDIT;
After rereading your statement, I went back and created 2 additional rules for 2/6 cameras I have... Called Cam1 No email, Cam2 No email.
After turning off the emails in the new rules ( toggle green check mark to black at email address ) I saved both.
They appear in the ALL ON MODE and no trouble to turn the rule on or off with the check toggle
So it is possible to do as you toggle on the NO EMAIL rules and toggle old one off...
If you can't pick more than one rule, something else is wrong and may require a reboot/reset
