Mode
I have a standard Arlo Go set up with a single camera, but I have just purchased another
When you set up a mode, can you save that setting, and then use another mode without altering the times, i did notice it said what are you going to call the Mode?
Message 1 of 2
1,315
The Arlo Go isn't for sale yet, AFAIK. It uses cell service to access the Internet as opposed to the standard wireless cameras which use a base station and your home network.
I'm not exactly sure what you're after but each mode can be as unique or similar as you like. I think you're talking about using the schedule. Whatever you have in your schedule will be used if the schedule is selected. If you select one of your modes, that's what will be used and the schedule will be turned off.
Did I misunderstand?
Message 2 of 2
1,307
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
