Logging into devices
  • 1 Reply
  • 1420 Views
kel075
is it possible to log into more than 1 device to be able to view from smart phones. Example: Hubby & i would both like to be able to view what is going on at home whilst at work from different smart phones using the Arlo app. Thank you in advance
Yup.  Create a guest account for one of you using Grant Access in Settings.  A guest login won't bounce the person using the master account off.  Note that even with admin access granted you don't have the overall same capability to change the system settings but can view videos and change modes.
