Is there a way to make it record longer than 10 seconds?
  • 4 Replies
  • 8752 Views
christina0373
We just purchased 2 cameras . Is there a way to make it record longer than 10 seconds? We need to make it record longer when motion is detected and 10 seconds is not enough time to record what these people are doing outside.
this should help ;
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-adjust-Arlo-video-recording-length/ta-...
FAQs are your friend
christina0373
i have done everything it said to do in that link and i do not have this option anywhere 😞 is there something else i need to do
  1. Click or tap your preferred editor pencil icon under Rules.
  2. Click or tap the pencil icon next to Record Video.
    Note:Record Video must be enabled to edit recording length.
  3. Move the Slider Controlto your preferred recording length.
No. When you edit your mode, Armed by default, you select the camera rule you wish to edit. In there are all the settings you can adjust.
It would be a good idea to just peruse the Armed mode and create your own custom mode for complete control.
go to MODE
click on Arlo base if modes don't appear on right side
click on edit " > " on ARMED
pick camera you want to adjust. click edit
click on > after RECORD line to edit
AJUST SLIDER first to right for more time, then use BACK at top of page
On previous page bottom is SAVE
