Is sensitivity REALLY set at camera level?
  • 4 Replies
  • 2366 Views
PaulOckenden
He's my current test situation:
If motion on A record video on A
If motion on B record video on B
If motion on A record video on B
If motion on B record video on A
If motion on C record video on C
So as you can see, A and B are linked via triggers, but C is completely separate. C is also this last rule in the list (that might be important).
I've noticed that if I turn the sentivity of that last rule (for C) up to 100, A and B also trigger much more frequently.
This is 100% reproducible here.
P.
While I don't use nested rules, I believe the suggestion is to use the same settings for all cameras for exactly this reason.  No idea why they're coupled like that.
PaulOckenden
That's been recommended where one PIR triggers who recordings (A  and B in my example above), but it shouldn't affect C surely?
P.
I'd say its the logic in the software. If it's wrong, opening a case with support raises awareness and tracking.
PaulOckenden,
Thank you for the report. I will escalate this topic for further investigation.
