How to stop the emails?
Message 1 of 2
1,497
Very easy.... Go to MODE, and on the one your using, click on the edit pencil. Then pick camera, and then drop down and UNCHECK the send email box.
You must do it for each camera as they can be set differntly.
As a PS;
you can and its recommended to create a custom mode same as the one your using and edit the emails off there. Then if needed you can instantly turn them back on if wanted ( by picking the other mode ) and you also don't change the default mode.
Message 2 of 2
1,489
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
