  • 6 Replies
  • 4063 Views
Dartman
 I'm still investigating buying an Arlo system.  Seems to be a pretty good way to go. I'm wondering how much time will record on a 128GB SD card (yes, I know it's sold separately) before the video starts to wrap and delete the old file(s).  Let's assume I'm recording 24/7.  I'm not looking for an exact answer; just an estimate will do.   Is it an hour, a day or number of days or weeks ?   Is there a rule-of-thimb that I can use for 124/7 recording in GB/HR ?
DM
Don't know when it showed up but 37.6 minutes at 720p was 137MB. Probably not the best way unless you're sittin g there monitoring things. That's over 5GB per day and 1080p would be roughly double that.
6 REPLIES 6
You can't record 24/7. 2 minutes at a time is it although I have to say I haven't tried live viewing and recording for long periods of time. Maybe but I doubt it.
Dartman
OK.  So no CVR recording, that's too bad, but how large is a 2-minute video.  I'm just trying to see how much storage I might need.
Thanks for the help.
DM
My 2 minute 1080 recordings are on the order of 6-8MB.  I'm in the process of attempting a long recording via live view to see when/if it times out.  5 minutes so far...
Welp, tried a 35 minute live recording.  Everything indicated it was happening but it's not in the library.  Perhaps it will show up later or not.
Dartman
All,
Thanks very much. Some quick math tells me a 128 GB card will yield about 22-24 days of recording (At roughly 3.6 - 4.0MB/Min). That's plenty of time for me (and makes one realize how much storage 128GB is!!)
