How do i shut camera off while I'm home
Notification keeps going off every time I move can I shut it down while I'm home?
Message 1 of 2
2,675
You can log in, choose the Moore tab and then your system, followed by selecting the Disarmed mode. That turns off all cameras. You can also use the schedule to do this automatically if your routine is consistent. Finally, you can try to use geofencing so it arms or uses the schedule while you're away and disarm the cameras when home. There seems to be problems with the latter if you want to try it out so keep an eye on it.
Message 2 of 2
2,665
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
