Enable schedule
  • 1 Reply
  • 2373 Views
MarthaPark
i canon figure out how to enable the schedule for the cameras.  I go in to the schedule screen and can add times to turn on or off each camera, but then it tells me that the schedule ability is disabled.  Is that because I just have the basic plan?  Do Inhabetompay for a more advanced plan in order to use the scheduling ability? Thanks.
I have the basic plan and use the schedule with no problems.  Where do you see the the schedule ability is disabled?  Never seen that.
