Download more than one day of video?
  • 1 Reply
  • 15026 Views
  • 2 Likes
hokeysmoke
Virtuoso
Virtuoso
Since cloud storage is limited, and the videos recorded are pretty small, I was wondering if there is any easy way to batch download them.  It appears that you can "select all" in the current calendar view, but the view seems to be limited to a single day.  Can I download more than one day's worth?
It appears you can only pick "select all" for each day as you've seen...
sound like you should put in a 'wish request' to Netgear.
see   https://community.netgear.com/t5/Idea-Exchange/idb-p/arlo-idea-exchange
PS... as a tip, anything "deleted" ends up in the trash bin for 7 days before being deleted automaticly ... so you can drop some there as your max limit is hit and still get them back later ( trash bin does not count towards the total used ! )
