Delete Email Addresses
  • 4 Replies
  • 23442 Views
lyvwyre
How to delete duplicate email address on list of  adresses to be alerted when rule activates ?
lyvwyre
Thanks for your reply TomMac. Followed your instructions a few days ago and the check mark was set to black. It doesn't send an email but it didn't delete the address. Guess I'll have to live with it. Thanks again.
go to SETTINGS, RULES, pick camera and go to "email alert to this list" ( click arrow ) and the ncheck or uncheck email address ( green is active / black is off ) then click save before leaving.
if it doesn't delete it the next time around, at least it won't function to send dups
lyvwyre
I deleted an address by doing the above. One point that isn't always obvious is to ALWAYS look in the upper right corner for Save since some actions require that you hit Save multiple times. Just saving once may not save the next screen.
lyvwyre
TomMac & jguerdat,
I went and made sure the address I wanted to delete had a black checkmark and then hit save. I then signed out and then signed back in. The green checkmark was back again. I repeated this a few more times and it still turned to green. I changed it back to green one more time and after hitting save and then signing out I walked away for a couple hours and then signed back in again and this time it took. The address was finally deleted.
