Can't get motion detection to work to save my life
  • 10 Replies
  • 48059 Views
  • 10 In Conversation
shopkins1994
Hi Everyone. I just got in my two camera system and I cannot get motion detection to work on either camera. I do the "Motion Detection Test" on both cameras and neither one "Flashes it's amber light" no matter what I set the sensitivity to. I have both cameras pointed in a room and I walk in front of the camera, across it's path at various distances and nothing. Nada. I also cannot get it to record anything, even with "All Motion On" mode enabled. I can view both cameras in the live mode though. It's just that no motion is ever detected.
Any ideas? This is driving me crazy.
Thanks,
Sam
10 REPLIES 10
MelvinRusk
I'm having the same exact problem!
Scott-B
I am havinf the same problem on one camera,
aalt69
Hey all, you need to update your firmware for base and then resync your camera. Had the same issue and as soon as updated to FW for base to 1.3xxxx all worked (Motion test led). I went through some other steps via netgear help, but I think if you go to your base station setting turn off your auto update, turn back on and click restart button it should update. Your box led turns Amber then turn green, then turn Amber again and finally all three green led will turn back on. Re sync camera with base. That should take care of issue.. If not I can try and recall what I did exactly and post. Good luck! Sorry for any typos and grammar. It's late for me and typing from phone.
BTW, current versions should be as of this post;
Base      =  1.3.2261
camera  =  1.2.2222
L_J
Motion detection is failing for me too.
My FW Version is 1.2.1728 and my Auto Update FW is set to on.  How do I force the FW upgrade to a version that will fix motion detection?
Log into Arlo;
  • Select Settings > Base Station.
  • Make sure that the Auto Update FW setting is set to the on position.
  • Restart your Arlo base station.
DianeG
I too, am having issues with motion detector.  I've done everything I can find and it stil doesn't work.  😞
David_NG
Hello DianeG,
Are you having troubles with one camera or both?
jashline6811
I had the same problem until I switched off the scheduling slide tab, then it worked. I wish I could make it more sensitive....
ChristineT
Good afternoon DianeG,
Were you able to get your motion detection working as expected? If so, what did you do to resolve the issue? If you still need further assistance please let us know and we can open a support case for you and work with you directly.
I look forward to your update!
Best Regards,
Christine
Arlo Team
____
Please click KUDOS or REPLY if you found this helpful.
