Camera Defaults to "do nothing" status
  • 2771 Views
BlakeB
I have the Arlo Pro base station and 3 cameras.  I have 2 set to "do nothing" if motion is detected.  The 3rd camera is set to record if motion is detected.  The 3rd camera will detect and record fine for a few times.  Then for no reason I can determine, it changes to the "do nothing" status and detects the motion, sends me an alert, but does not record.  Any suggestions?
steve_t
Master Master
Do you have smartthings integration?
BlakeB
No.  I do not know what smartthings integration is and don't intentionally have this integrated.
steve_t
Master Master
For the cameras that you have "Do nothing", I recommend you delete those rules. Any cameras with no rules will automatically do nothing. Only if you want it to record or notify you via push or email should you need to create a rule for that camera in the mode you're using
