Arm/disarm
  • 1 Reply
  • 1517 Views
mikeavs
Got 2 cameras - 1x Front, 1x Backyard and have created a new custom mode. I am having 2 cameras armed at night which is the way I like. How do I go about if I want to disarm the camera at the backyard? Do I have to edit the custom mode and remove delete the 2nd camera? Is there no check mark how it used to be at the ver very beginning when the app was developed? I believe there was a way to edit the custom mode and either check or uncheck cameras. Now, there is a check mark but I cannot do anything with it. It's always checked so the only option is to edit the mode and delete the camera and then re-add it back if I want the camera to be armed at night. Weird...
The default Modes arei Armed(all on) and disarmed ( all off).
Create two new modes one for Front and one for Back.
So now u can can have All on, or front,or back.....any camera not in the running mode will be off...u can only run one mode at a time
