Arlo wirless
  • 1 Reply
  • 1611 Views
DMon707
I use the camera to monitor my koi pond while traveling. It's easy to log in and take a quick look at the water level in the pond, but if I want to check to see if the feeding machine is working, I have to log in at the precise time of day that the machine operates. It would be helpful to have the cam operate automatically for a minute or so one day per week to observe the koi feeding at the machine. The motion sensor doesn't activate for koi no matter how sensitive I set it and even though the camera is right next to the pond. Otherwise that would be the obvious solution.
Am I missing a way to program the camera to record a minute evry week, regardless of motion detection?
Not at this time...
