Arlo pro - increase recording time
  • 7 Replies
  • 11090 Views
  • 5 In Conversation
Eliza4
How can I increase the recording time?  I am using the basic subscription.  Thanks
Go into the MODE your using
hit > to edit
pick camera click to do and use edit
Drp down to record video, hit edit
adjust slide bar for time
save as backing out
7 REPLIES 7
hit > to edit
save as backing out
parkersages
How do you save it I can see nowhere where it save or back
parkersages
I've found a way but I'm sure it isn't what was intended but it's done the trick
You're right, the Back selection is missing and has been reported. Use the bar at the top for Edit Rule to go back to where you can save.
parkersages
Thanks, I discovered that by trial and error
Str8key
Default video length is only 10 seconds, only gives me brief periods of activation. How do I set it for longer duration upon activation?
Search and FAQs are your friends. Use the Mode tab, select your base and edit your modes. Create custom modes while you're there so you have complete control. All settings are in your modes and rules.
