Arlo Scheduler
  • 1 Reply
  • 1883 Views
jsgarlo15
I have the scheduler set correct "green areas" for motion on 10:15 -5:30am, "gray areas" for motion off 5:32am to 10:13pm, Here is my question when I turn scheduler on, for names sake we will call them camera  #1 & #2  to detect motion every night at the same time for each camera from 10pm to 530 am in a parking lot I do not see the "running man" icon in the "camera tabs window"  lit up in green when its 10:15 pm, the time I thought schedule would kick in. Should it be on to tell me motion detection is activated for that time period ?
And it does not turn off because, I am still receiving texts at 5:45 am in the morning when people are coming into the parking lot, should it not be turning off as well according tothe set time.
Obviously I am missing a step along the way in rules /modes etc that is not allowing my schedule to kick on ???
I have the same modes under the settings tab for both cameras 1 & 2 the same... All Motion On & All motion Off, should all of these be checked on or off or  what for the schedule to work properly ??
Thanks JSG...
jsgarlo15,
If the running man icon is grey that means that motion detection is not active. If it is green that means it is active. Check your "all motion on" mode to make sure that the rules that tell each camera to record upon detecting motion are active. After you have determined the rules within the "all motion on" mode are active, check your schedule to make sure that the "all motion on" mode is active during the time frames that you want the cameras to detect and record motion.
I hope this helps!
