Arlo Pro combined with Arlo Go
  • 7567 Views
bearrito
Is is possible to use both an Arlo Pro with an Arlo Go.
I understand that an Arlo Go will not use the basestation. However, can I view both Arlo Go and Arlo Pro through the same instance of my app e.g. Will my user experience present them as being part of the same unified system.
Streak2
Master Master
Yes. No problem. I have he same setup. In fact I have the Go, Q, Baby, Pro and Pro 2 all on the same app/account.
Streak2
Master Master
bearrito
Does the Arlo Go show up under the same "Mode" as the Pro's. In other words, can I disarm/arm/schedule/geofence all the units together or do they show up under different modes.
I'm assuming all cameras show up the same way under devices?
Only the cameras that use a base unit ( arlo,arlo pro,arlo pro2 ) can be armed  as a group per base... as the command is to the base.
The Q cameras, Go, and Baby must all be armed as indivdual units
( tho all the cams will appear in the same web/app )
