Add rule in "Armed" mode
I have 5 wireless cameras but there are only 4 rules in Armed Mode. And there is no option to add rules in this mode. It means one camera is inactive when the system is armed. Is there a way to fix it instead of creating a new mode?
Message 1 of 2
1,041
I'd recommend a custom mode in the first place but to fix the Armed mode you likely would have to reset the base, remove all devices in Settings, My Devices and start fresh using the Add Device button in the Cameras tab to add the base back in and sync the cameras. That will rebuild the Armed mode and should have all cameras in it.
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
