adding more cameras
i bought 2 4 packs of cameras from Best Buy but i can only hook up 5 cameras. how do i hook up the other 3?
Message 1 of 2
2,206
The BASIC plan ( free ) supports only 5 cameras.... that may be the problem.
In order to use the 3 additonal you would have to upgrade your service to the next level which will support 10 cameras. Also, advantage here you also get much more storage and # of days to store video.( 10gb/30 days )
Or run two separate accounts with different id/pw if you have more than one base station.
Message 2 of 2
2,195
