Where can I buy the Arlo HD Security Camera Add-On Mounts?
  • 5 Replies
  • 21204 Views
  • 4 Likes
  • 5 In Conversation
gsshaw
The Arlo website lists Amazon on the "Buy Now" button link from the website, but shipping on the Indoor/Outdoor Mount and Table/Ceiling/Wall Mounts are 1-3 Months.
Needless to say, that's a really long time, and Best Buy didn't have the Add-On Mounts available, just the camera kits, so its frustrating to have to potentially wait that long to get the system set up if there are no retail outlets available to buy the camera mounts and Amazon is sold out for so long.
Any thoughts or ideas?
Adjustable Indoor/Outdoor Mount (VMA1000-10000S)
Table-Ceiling-Wall Mount (VMA1100-10000S)
DavidR79
I got the VideoSecu Universal Adjustabel Camera Mounting Bracket from Amazon, and it is OUTSTANDING! Great product. Doesn't do too much for security of the camera, but it gets the job done as a mount.
http://www.amazon.com/VideoSecu-Ceiling-Bracket-Camera-Adjustable/dp/B000X23I22/ref=sr_1_1?ie=UTF8&q...
For 6.99 you can't beat it!
David
5 REPLIES 5
There is a back log of the Arlo mounts... as a suggestion, almost any threaded camera mount will fit the screw hole in the camera bottom...it is the standard thread for these  ( 1/4 - 20 I believe ).
Or something like these;
http://www.amazon.com/Adhesive-Camera-Mount-Tripod-Thread/dp/B00GYG16E8
( made sure adhesive is strong enough )
DavidR79
David
Hula_Rock
Prodigy Prodigy
Prodigy
David
I bought the same product and Highly reccomend it!  I servived the Monsoon Rain/Tornado Warnings we had in South Texas over the weekend.
BLK
I just cancelled my Amazon order for the Netgear mounts. Saved $80 and in stock. Thanks for the recomendation!
Hula_Rock
Prodigy Prodigy
Prodigy
Hint:  once you screw doewn the camera make sure you also tighten the round looking COG.  It helps secure the camera.
  • 5 Replies
  • 21205 Views
  • 4 Likes
  • 5 In Conversation
