							Useful tip for those not wanting to climb ladders
(Posted on wrong board initially)
Most of my cameras are mounted 3-4 feet out of my reach on the silver magnet ball mounting mechanism. I'm not old or decrepit, yet the thought of climbing a ladder up to 10 times every few months to change batteries gave some discomfort. It's just a matter of time before I hurt myself... So I went out and ordered one of those reach extenders (51 inches) not knowing if it would be strong enough to pull the Arlo camera off the magnetic mount. In any regard, it arrived yesterday and it worked beautifully. The strong gripper is even precise enough to manipulate the cameras aim pretty well and all without having to climb a ladder.
I posted a link to the product I bought below (51 inch reach), but I suspect other similar ones probably would work fine.
Unger Nifty Nabber Extension Arm with Claw, 51 Inches, Black/Green (NN140) https://www.amazon.com/dp/B001KPUAN6/ref=cm_sw_r_cp_api_3vXyxbJD2Q26G
Huh. Hadn't thought of that. I have one from years ago that I'll try. Thanks for the tip!
That's a great idea!
Ettore 49150 Grip 'n Grab Reach Tool, 50-Inch https://www.amazon.com/dp/B005KUBWZ2/ref=cm_sw_r_cp_api_Q7Qzxb0BHDBPB
It makes the OEM vs rechargeable decision much easier.
