Safe from hackers
  • 2 Replies
  • 23885 Views
  • 3 Likes
8Y2vj
I recently installed Arlo cameras.  I am wondering is there something I should be doing to keep my cameras safe from hackers since it is on a wifi network?
4vrnvr
As long as you have secured your WiFi network you should be fine.
Greg
Netgear has stated the stream is encrypted...
Verisign is used to access during login.
Prior post;
"I found out the unfortunate answer from a Netgear product manager.  The RTSP stream is encrypted and thus cannot be used to integrate with other software.  This makes the Arlo a security device not a surveillence one.  My clients will not be able to use it."
  • 2 Replies
  • 23885 Views
  • 3 Likes
