Record Time of Usage until Replacement on OEM Battery - Non-Rechargeable
  • 6 Replies
  • 3457 Views
  • 7 Likes
JPC
Prodigy
Prodigy
Here's my way of keeping record.. If you want to Add yours, Pls. do and use this format if you want.. Thanks!
Remember, this is for OEM (Non-Rechargeable) Battery..
Battery Name: Panasonic
Specs:1550mah / 3v
Where Purchased: BatteryJunction.com
Approximate Rate of Usage per Day (High-[11min & Up] / Med-[6-10min] / Low-[1-5min]): Medium
Date Started: July 16, 2015
Approximate Date of Runtime 3-Bar Indicator Full Ended:
Approximate Date of Runtime 2-Bar Indicator Med Ended:
Approximate Date of Runtime 1-Bar Indicator Red Ended (Camera Prompt [Pls. Replace Battery Now]):
Approximate #Days Total Count for Replacement:
Add:
Battery Name: Energizer
Specs:1500mah / 3v
Where Purchased: Target
Date Started: July 9, 2015
Follow-Up Coming Soon....
6 REPLIES 6
RobertRosal
Virtuoso
Virtuoso
Specs:1500mah / 3v
Where Purchased: Came with Arlo
Approximate Rate of Usage per Day: High
Date Started: April 29, 2015
Approximate Date of Runtime 3-Bar Indicator Full Ended: May 19, 2015
Approximate Date of Runtime 2-Bar Indicator Med Ended: June 18, 2015
Approximate #Days Total Count for Replacement:  51
-Robert
RobertRosal
Virtuoso
Virtuoso
Battery Name: SureFire
Specs:1300mah / 3v
Where Purchased: Ebay
Date Started: May 19, 2015
Approximate Date of Runtime 3-Bar Indicator Full Ended: June 08, 2015
Approximate Date of Runtime 2-Bar Indicator Med Ended: July 15, 2015
Approximate Date of Runtime 1-Bar Indicator Red Ended (Camera Prompt [Pls. Replace Battery Now]): 0
Approximate #Days Total Count for Replacement:  58
-Robert
JPC
Prodigy
Prodigy
Specs:1550mah / 3v
Add:
Specs:1500mah / 3v
BATTERY UPDATE:
Specs:1500mah / 3v
Approximate Date of Runtime 3-Bar Indicator Full Ended: Sept. 15, 2015
Approximate Date of Runtime 2-Bar Indicator Med Ended: Sept. 19, 2015  <-- Still works in stable State
Approximate Date of Runtime 1-Bar Indicator Red Ended (Camera Prompt [Pls. Replace Battery Now]): Sept. 22, 2015  <--- Not so stable, Streaming/Recording flaky but it detects motion triggers to my other camera, until it just went Dead
Approximate #Days Total Count for Replacement: 75 days until it totally went dead..
My Panasonic is still holding Strong in Full Bars.. We'll see how it holds up!
Here's a partial info ( 2 cameras , so 2 sets of batteries )
Specs:1500mahr / 3v
Where Purchased:Walmart
Approximate Rate of Usage per Day (High-[11min & Up] / Med-[6-10min] / Low-[1-5min]): Very Low  ( 1-2 mins week view, 4-5 days week sense/6 hrs )
Date Started:Feb 24,'15
Approximate Date of Runtime 3-Bar Indicator Full Ended:STILL FULL
So far running aprox 7 months / 210 days
JPC
Prodigy
Prodigy
Specs:1550mah / 3v
Add:
Specs:1500mah / 3v
BATTERY UPDATE:
Specs:1500mah / 3v
Camera Settings: Motion Detection = 100%, Sensitivity = 97%, Recording = 25 seconds
Battery Update:
Specs:1550mah / 3v
Approximate Date of Runtime 3-Bar Indicator Full Ended: October 10, 2015
Approximate Date of Runtime 2-Bar Indicator Med Ended: N/A
Approximate Date of Runtime 1-Bar Indicator Red Ended (Camera Prompt [Pls. Replace Battery Now]): October 12, 2015
Approximate #Days Total Count for Replacement: 88 days/ About 2 Months and 26 days
Camera Settings: Motion Detection = 100%, Sensitivity = 95%, Recording = 25 seconds
Panasonic sure do holds a bit more than Energizer but I didn't expect the indicator to suddenly drop from full to just 1-bar..
JPC wrote:Panasonic sure do holds a bit more than Energizer but I didn't expect the indicator to suddenly drop from full to just 1-bar..
Yes. also noted on mine... at 7 months when I posted ( info a couple entries up ) they were full.
One week later the email came the bateries were low... 15% I believe ( not sure ), I changed them out but let the other camera continue.
It went to 2 bars after another week, then dropped to 1 bar the next day.
So, from full to 1 bar in two days while lasting 7+ months is fast drop out on indicator ( only one day at 2 bars )
  • 6 Replies
  • 3458 Views
  • 7 Likes
