Rechargeable batteries
  • 2613 Views
Vallorie
Luminary
Luminary
I brought the Edison Rechargeable batteries about a month ago -- do you guys think they will be safe to use?  Also I have quite a bit of lag time when playing back camera shots - sometimes by the time playback I missed what caused camera to take the shot - is it my phone or the lag in this system?
Vallorie
Vallorie
Those are unknown to me... web page? purchase from?
Most being test/run now are 3.7v li-ion in a 123 or 16340 format size , capacity maxs at about 700mahr with PCB safety device
Yes there is a delay with the startup of the Arlo cameras, but it is workable... the sensor is most sensitive on the edges and motion is better accross rather than straight at the camera.  Setup and be trial and error till it works well. Try not to cover to much area at once as the PIR sensor is good to a max of about 20 ft.
Vallorie
Luminary
Luminary
I obtained them from Amazon--
4 Pack Genuine EdisonBright RCR123A 650mAh rechargeable protected li-ion type 16340 batteries with BBX3 battery Box
 Li-ion 16340 RCR123A battery
  • 650mAh capacity
  • Built in protection circuitry
  • This bundle include four EdisonBright RCR123A batteries and battery carry case.
They may or may not fit.... Some are to long in allowed variance
Also I assume they are 3.7 v... If so should be ok
read the previous info on rechargeable ( at least the last few pages)
  • 2613 Views
