How do I increase from 5 to 7 cameras?
  • 1 Reply
  • 3155 Views
pdupuy4649
Buy them? 😛
The biggest issue will be how you want to use them. The basic plan only allows for 5 cameras so you'll need to do one of two things:
1. Upgrade your plan at additional cost.
2. Use the new cameras with a second base station and set that separate system up using a second email address. Both systems can use the basic plan that way.
If using option 2 you can add yourself as a friend on one system to use the same email address as the other so you can use one login to see both sets at once. Otherwise, you'd have to log out of one and into the other.
Buy them? 😛
  • 1 Reply
  • 3156 Views
