Base station can be used with 220v
  • 1 Reply
  • 2420 Views
Jj11b
I am located in hongkong just wondering if the base station can support 220voltage
The base uses a power adapter that outputs 12 dc ( center +, 5.5mm coaxial plug )at 1.5 a max.
So either use a 120v adapter to plug it into or get a 220v to 12 dc adapter of similar type if the non-US version doesn't supply one for 220v.
  • 1 Reply
  • 2421 Views
