- English
- Arlo Forum Discussions
- Buying Tips
- Arlo Wire-Free or the Arlo Q camaras and AC1900 Wi...
Arlo Wire-Free or the Arlo Q camaras and AC1900 Without Base station?
Are the Arlo Wire-Free or the Arlo Q camaras compatible with AC1900? I am building a new home with Time warner internet NETGEAR R7000 Nighthawk AC1900 Dual Band Wireless Gigabit Smart Home Router w/ Arlo Wire-Free Security Camera Support and ARRIS SurfBoard SB6141 DOCSIS 3.0 Cable Modem. I dont want to purchase the base station if I don't need to. Is the ARRIS SurfBoard SB6141 DOCSIS 3.0 Cable Modem WITH a Phone line or do I still have to use Time Warners Modem. Thanks
Message 1 of 2
989
Currently, only the R7000 is capable of acting as a base station so you're good with that. You may need to flash the latest firmware to enable that. Also, I use the same Motorola 6141 modem with no issues. I ditched TWs modem when they started charging rent. The combination of modem and router should be totally usable by you with only the Arlo camera.
Message 2 of 2
964
