Arlo Camera battery
Is Panasonic a good brand as per arlo usage.Also can you suggest a comparatively affordable brand of rechargable battries in Canada. Its too expensive here even if I get from US the shipping cost kills.
Message 1 of 2
1,451
Have had no problem with the Panasonic branded 123 batteries... any "well known" brand of that type 123/lithium battery will perform almost the same.
But, I do find them pricey if bought local, so I usu buy only from the online battery supply houses at aprox $1.40-$1.50 per ( don't know how much tariff effects you )
