3-story condo
  • 2 Replies
  • 1997 Views
SGSW
I live in a 3-story condo.  I have a very small front porch.  If someone is at the front door, I want to know who it is before I run down all the stairs. For example, if it is just UPS delivering a package, I don't need to go down.  I'm thinking of getting 1 Arlo to do this.  I don't care about recording or sound, I just want to be able to look at my iPhone or laptop and see who is there.  Will this work for me?
I live in Hawaii, so the reported problems of the camera not working in cold weather should not be an issue for me.  😉  But we do have a lot of humidity.  Will this be a problem?
Also, I'm a bit confused by the router.  I already have a wi-fi router.  Does the Netgear router plug into that one? Or where does it go?
Any advice would be greatly appreciated!
Thank you.
It would work but it's not as simple as just looking at your phone.  You'd need to start the app and click on live view, which takes a few seconds to start. If a 10-20 second process isn't a problem, this should be fine.
The base station simply plugs into the router you already have - no need for yet another one.  The base station could be thought of as a router but only for the cameras.
ValleNorte
I have the app always on in the background so I just need bring it to the front and click on camera to view. This takes about 10 seconds to 'go live'
  • 2 Replies
  • 1998 Views
