why does everything green show as purple?
vector13,
Reboot the camera by opening and closing the battery compartment door. Allow the camera to sync back up to the base station and try again. Are you still seeing the same behavior?
I DID AS YOU SUGGESTED. STILL ALL GREEN SHRUBS ARE STILL PURPLE ALONG WITH A SLIGHT PURPLE HUE TO THE CLEAR PICTUE... THANKS
vector13,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
