water inside of camera
  • 1 Reply
  • 2981 Views
lifebeginsafter
i noticed on one of my cameras that when i went to change batteries after they were charged and then getting a warning that batteries low, when opening the case, water came out. At first it was moisture but built up to water coming out after raining. I make sure the battery compartment is closed tight. i've looked on forum with posts of same issue but didn't see, maybe overlooked? tks for reponse
I would do two things...
1) check the o-ring seal to make sure it is ok, wipe a bit of silicon grease on the oring if you have any ( not petroleum based ) before closing
2) open a case with Netgear Support if under one year for possible warranty claim
