i am trying to set up my arlo pro camer system. when i try to login i get unable to claim this device. i called support thet said that there is a problem with my router set up. the signal coming in is fine. there is conflict within the router. i called my internet provider they tryed to clear the issues up. they added a second login adress. this is on a different frequincey than the other. this still didn't fix the issue. how do i check and clear up any issues within the router.
thanks for any help
craig9176
Craig9176,
What is the LED behavior on the base station (Power and Internet LED).
When going through New System setup, the device you are using must be on the same network as the base station. Be sure the setup device is on the same network and try again.
reginasmith,
Can you give more detail on the issue you are experiencing? What Arlo product do you have?
At what point during the New System Setup process are you having trouble?
