setting up my Netgear base station , and the sync light does not come on
The sync light des not come on after holding the button
Orscher,
Do not hold the sync button. Briefly press and release the sync button and this should result in a flash green camera LED on the base (center LED). This means the base station is ready for a camera to sync.
I have the same issue with mine. The sync light on the base station won't come on. Tried holding for two seconds - nothing. Removed the device and aded it back to my account - nothing. Did a hard reset - nothing. Don't know what else to try. Should I return to Best Buy?
Brief press the sync button - <1 second. Any luck?
