repair shop?
I have 4 Arlo cameras. 3 are broken. Might anyone have a suggestion for a repair shop?
* 1 has infra red stuck on
* 1 flashes blue light on one side only, doesn't connect
* 1 doesn't show any signs of life (I had tried using baking soda with vinegar when I saw a little corrosion on the contacts, not sure if that was the kiss of death)
My 4th camera is working fine.
Not possible especially since parts aren't available. New cameras are the "solution".
I have to add that I tried to fix the infra red issue by turning the camera upside down and rotating the view 180 degrees. It worked for awhile, but now back to infra red.
Thank you. You are right. I'll go with Blink cameras from now on - Arlo won't help you unless you pay $$$ to ask for help.
