Last night the base station lost service to the internet so i reset my router and it reconnected but now the 3rd light on the base station is amber color and I cannot get any of my cameras to connect. I even removed 1 camera and tried to re-sync it, it does not show up when i log into my app but the camera lights up when movement is detected. I even reset my base station and it still will not connect to any cameras. Does anyone have any suggestions?
Power down your modem, router and base unit....
Bring them back on line one at a time allowing each to boot fully. ( same order )
Check the cameras after a couple mins... If they are not there, you may have to resync them to the base as if new
A solid amber Camera LED means the base needs to be claimed. Remove hte base from Settings, My Devices and then use the Add Device button on the Devices tab to add it back. You'll likely need to resync the cameras.
